Discuss advice on marble installation in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
Hi i've just got a job tiling three bathrooms in polished marble has anyone got advice on cutting curves and grouts to use as i have not worked with marble before. Cheers
Marble is really soft stuff. If you have bedded a tile in and then need to lift it, say to correct levels, be very careful how you do it as the tiles break very easily! They also scratch very easily. I didn't need to cut curves when I laid my floor so can't comment on that with regard to marble.:thumbsup:
MICK the Tiler
Invest in some suction cup lifters these will help with moving tiles around, also allow for plenty of addy. The marble I'm working with at the moment varies in thickness by 5mm:mad2: as for cutting curves use an angle grinder and i use some lead solder as a flexable ruler to get the shape then I freehand score with a hand held glass cutter makes it easier to see the mark. Be careful when marking marble with pencil it can be very stubborn to remove so mark out accurately.:thumbsup: For grout the smoother the better.
Deleted member 1779
In addition to straight line cuts and curve if you also need to drill holes you will get best results from diamonds. As mentioned above marble is really soft and in the past we've managed to dry drill it with our core drills.
Some marble actually drilled better without water - than with.
The other point above about being careful with pencil marks is valid too. In fact we always use masking tape on marble as a barrier to penetration.
Reply to advice on marble installation in the British & UK Tiling Forum area at TilersForums.com
Hi, in anyone’s experience, would gypsum plaster irreparably stain marble tiles? In my bathroom...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
