Discuss advice on marble installation in the British & UK Tiling Forum area at TilersForums.com.
MICK the Tiler
You may need to seal the marble before you start if it is a light colour then I always seal both sides before fixing.:thumbsup:
I actually think that's a pretty good idea, I mean we seem to have no probs in priming floors and walls, effectively sealing the surface, Does that affect adhesion?
TilingLogistics
Why is that kev?
I thought that a certain amount of the cementitious properties in the adhesive actually adhered with certain amounts of it penetrating the biscuit to the underside of the tile. My thought process naturally led me to believe by sealing the underside of the tile with a penetrating sealer it would affect adhesion! Am I wrong?
Kev
MICK the Tiler
I think the word "WRONG" in the way you describe how a sealer would affect the ability of an adhesive to stick to a tile is a little early at this stage. I mean alot of you guys seal your tiles before you grout, would this affect how the grout grabs the edge of the tile? I think this technique is very interesting and would like to have more discussion on the topic, perhaps a test board with some tiles attached or some input from an adhesive rep may be the way to go, It would certaily go a long way in solving "Bleed Through" issues on translucent stone. Although it would be an extra cost that would have to be allowed for in the costings. I don't think either of you are wrong in what you say. There simply is no evidence to support or disprove either argument at this stage.
The D
Hi Mick I have used this method for 25 years and it was being don by my family before I was born. It is a tried and tested method as long as you use a modified adhesive there is no problems we see no problems with adhesive sticking to porcelain I have even been known to dip the marble so it is sealed on the front, back, and the edges and then you can use any colour adhesive that you want. I did a floor for a builder in there head office and had to chop one out and believe me it was stuck.
Spud
deano sealing tiles can effect how the adhesives bonds to the tile depending on which type on sealer is used ,some marbles and stone have to be sealed but with spirit based sealers rather than oil/parafin based sealers as these would form a barrier , have you heard of feb strike? this is an oil based sealer for shuttering to stop the concrete sticking to the shutter same thing would happen to tiles if you sealed with an oil based sealer so yes you can seal the backs but just be careful what you seal them with
The D
Yep I’d agree with that. :thumbsup:
TilingLogistics
Dean
You are bringing a lot of different things into the equation now. I have no doubt in my mind that you have done what you have done for a long time and I am sure what worked for your family and you was fine. However, we need to remember sealers have advanced a great deal as have, modern adhesives. As for using any colour adhesive on marble when its sealed brings other problems as well as sealing issues. Are you therefore saying if you dipped Carrara marble in sealer you would then use a grey adhesive to fix it?
Kev
TilingLogistics
Mick,
I believe most tilers /fixers who preseal would only use a temporary sealer to aid grout haze removal I certainly would anyway.
As for "bleed through" I have just had some very interesting results if you are interested maybe I could post them or PM them to you as I believe the findings may bore some people top death. In addition if you want me to post them i will need to obtain permission from the author firstly:thumbsup:
Kev
The D
Dean
Kev
Yes kev that is exactly what I am saying.
pjtiler
I did a bathroom floor and walls in Antico Marble. I used grey flexi and fixed before sealing. I used Granfix grout after 1 coat of Stonefix colour enhancer then sealed again after cleaning down.
Job looked brill and customer was well pleased (£200 tip pleased actually).
lead us a tenner:yes:
Reply to advice on marble installation in the British & UK Tiling Forum area at TilersForums.com
Hi, in anyone’s experience, would gypsum plaster irreparably stain marble tiles? In my bathroom...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
