Advice with prep.
Just starting tiling in Scotland, has been 10 years last time I was tiling back in spain. Things have change a lot, and is diferent from Spain as well. I would like to know the best way to do the prep and when to use backer board or decoupling mat, etc.. any recommendation on some kind of guide, web, demonstration on local shop? Thanks!
This could be quite a long answer, but instead what I am going to suggest is that you go online and look at , Schluter, and dural as regards decoupling membranes and have a look , tilemaster for antifracture mats , wedi, jackoboard and Hardie for backer boards . Then come back asking more specific questions on things that aren't clear after reading their tech guides .
I hope I don't get slaughtered for this as I or someone else could otherwise be writing for hours .
Thanks a lot. I will have a look at it, is a starting point. Back in spain when I was tiling allwais was a cement render base, we don't use timber, and plasterboar just some times. I want to do things in the proper way, and most important understand what to use and why in every different situation. Thankfully my local ctd are very helpful and they give me advice .
I totally agree with @jcrtiling, best thing to do is go around your local suppliers and see what is readily available to you, then go online and read the information available on their websites.
Any other queries after this then come and ask away 🙂.
They should have some info to give you on products they sell .
Ctd are a good company according to those that use them , I don't have a local one .
Advice with prep.
Enrique volta,
Enrique volta,
Enrique volta,
Enrique volta,
