UK Moisture in floor advice...please
Renovated the bathroom on my 1970
bungalow last year. Took up the old pink floor tiles with sds. Chunks of what i assume is self leveller or maybe screed (?) came up with them.
Left with Concrete slab. laid insulated coated (cement topped) tile backer boards (marmox) using a thick amount of flexible tile adhesive to make floor completely level. Laid 6mm marine ply over top of boards and then vinyl (for warmth).
Fast fwd 12 months, pinky stains through vinyl. Took it up, mould on underside of vinyl.
Took 6mm marine ply up, seems a bit brittle like it has moisture but nothing too bad. Bought floor hygrometer placed on backer boards and after 24 hours it's showing 75% (and it's been dry here for weeks).
So quite high.
I'm guessing I need a dpm and I know it should go under the tile backer boards but I don't want/can't take them all up (glass shower and tray is in) so I dont want to take that out again nor be using sds in there taking up all the tile adhesive underneath with chips flying everywhere. Ps. I cant add much more height.
I've bought tiles (porcelain, impervious to moisture) which should be more moisture forgiving than vinyl. Can I use a liquid dpm on top of the cement topped tile backer boards? Or even a normal dpm? Or am I better with some sort of ditra mat type thing and then tile on top of that? Ideally I'd like electric ufh with the tiles but realise that may make the relative humidity worse.
I know everyone will say take the tile backer boards up , lay dpm and put new tile backer then electric ufh then tile. But just checking if I can do anything else on top of existing backer boards....... 🙏 picture to show type of backer board as i was taking marine ply up. The stains on the top side of ply are just the old vinyl glue not water as such.
Thabkyou.
I've just removed the marine ply a minute ago. Ditra mat on top of those tile backer board still OK and will that stop the moisture coming up?
send picture
make sure the tile backer boards are well secured to the floor. Apply SBR then Ditra. Using Ditra mat will stop the moisture migration
Measured the floor with a floor hygrometer, rained yesterday and the RH on top of the boards was up to 82%. Seems to sit about 70% without rain.
Tile and vinyl say 75% RH maximum permissible level So I definitely need some sort of moisture barrier.
Tiler is recommending using some self levelling then epoxy resin on top to stop moisture.
Confused as to whether to do that or the ditra mat. Obviously the mat is easier.....
Thoughts anyone?
That is bad practice.
I noticed you have a shower enclosure there; did you check for any leakage? Those suspended shower trays t
Oh is it?
No I checked for leaks underneath the tray. All seems dry.
All rooms concrete floor read similar 75+ RH with the hygrometer, give or take a couple of percent so pretty sure its due to moisture/vapour coming up from ground but the carpeted rooms deal with it obviously the vinyl would let the moisture out into the room though
Ok thankyou. Do the channels in the underside of the ditra mat direct allow moisture to flow along their length? If so does that moisture end up going to the walls?
The backer boards are 100% moisture proof. That floor is ready to be tiled.
Uncoupling membrane speaking: if there are 2 sheets of Ditra on the floor, you may apply a polyethylene tape on the joint. If you are worried about any moisture getting to the walls, then you can apply tape to the walls as well.
Thankyou.
That's what I don't get, marmox boards are water proof yet the floor hygrometer on top of them reads 80% RH today at 20 degrees....and the Relative humidity in the floor will be even higher in winter when the floor is colder.
Tempted to spend a day, cover the shower glass and walls with protective coverings and sds up the boards and tile adhesive and start again, lay a 1200g polythene dpm on the bare slab, self level and put down new marmox boards or ditra, but as I can't get under the shower done 100% with the dpm sheet thats likely pointless/fruitless I guess
Hiya, concrete floor under the backer boards. Must be a few voids of tile adhesive under the boards. Couple of places you walk you feel the backer boards compress down a little over a small area. I've just drilled, rawl and screwed one defelction area using the large metal board washers to pull the areas down and that seems to work. Maybe I can do that in the remaining coupe of deflection areas, so that I end up with no defelection but obviously dips in the board from what would be level.
Self level over that (using moisture tolerant slc) to level it out, then ditra then tile I guess.
I wanted electric ufh for the tiles so was thinking electric ufh cables on top the ditra, but guess that could be a bad thing and make humidity worse as whilst warm air holds more water than cold air and so rh would decrease, but obviously warm air also expands and so may make things worse pushing the moisture upwards - but I could very well be wrong. I could only find a post or two on the internet whether ufh makes moisture better or worse, nothing conclusive.
Was that because you had a freshly laid screed or slab though which just needed to dry out ?
I think in this case if I did that it would only be a temporary fix - this slab was laid in the 1970s so it would have dried out a long time ago. As the moisture vapour in the floor is the same in every room (high) It seems to be an ongoing thing. Outside, perimeter drains may help I suppose but I think it's due lack of or failed dpc from the 1970 (dpc weren't regs until mid 1970's so it may or may not have one.
So dehumidifier would work initially but moisture would just build up again afterwards as it comes up through slab from the ground. Thanks for the suggestion though.
I put a piece of vapour barrier on top of the backer boards the other day sealed to the floor and puy the floor moisture meter on top of that - it read 80 percent without the polythene it and 70 percent with it. So that seems it would help, or the liquid dpm but I know you said that's bad practice on top of the backer boards.
I'm going round in circles haha.
The similar jobs I have done were flooded at some point and needed a dehumidifier, walls and floors. To attach the Hardie-Becker to the concrete Pros would use SBR, tile adhesive Rawl plugs and screws. The best bond is done on dry surface.
You know how to get on with the project now. Send us pictures during/after
Had this response on electricians forums. Thought I'd post it but I bet this is long sorted.
Rather than covering the issue, find where the moisture is coming from and address from that end, is the outside ground level above the inside, is this earth or a hard standing, path or road, do your gutters overflow, is there a drain of some kind adjacent to the external wall or even under the slab, these and many others can cause moisture inside a building, if you are sure none of these issues exist then the moisture in the slab can be prevented from rising with an epoxy resin tile adhesive, but this may just move the problem into the walls if not laid correctly, better to find out why and address that.
Just looked on the Tilers forum at the pictures and would suggest that the shower or WHB drains may be the problem, check the shower tray for cracks, find the external connection for both and block the drain, fill the shower tray and WHB with water and see if the level drops.
UK
sparkymarky78,
Dan,
sparkymarky78,
Dan,
