Discuss anhyrdrite screeds in the British & UK Tiling Forum area at TilersForums.com.
JOHNNYCLARKE
About to start a job monday and just found out the screed is pumped anhydrite.
Screed been down 2 weeks over water underfloor heating so I have been on to mapei/weber etcc and screed company for advice.
They all say the same that you should allow 1mm thickness of screed per day drying before tiling.
This is similar to fibrous screeds for underfloor heating unless where ditra mat or similar used, in which case can tile onto screed within days.
But you must scrape skin off screed and prime floor first in either instance with anhydrite.
This screed apparently expands rather than contracts and can blow tiles off subfloor.
So I know what route to take, using ditra which I quoted for over fibrous screed that would have been down for only two weeks as well.
MY QUESTION IS , HAS ANYONE HAD A PROBLEM WITH TILES NOT ADHERING TO THIS ANHYDRITE SCREED BEFORE.
APPRECIATE ANY INPUT
Cliff Anger
cant emphasise this enough - yes we get phonecalls almost daily about failures on anhydrite screed - this stuff should be banned !!!
Anhydrite is made from Gypsum and is not chemically compatable with cement adhesives.
The anhydrite MUST be completely dried out....prepared and primed so it is completely sealed . if the primer fails the adhesive fails !
Much has been written about the formation of ettringite crystals - which form when cement, gypsum and moisture get together - they expand pushing off the adhesive and the subsequent tiling
JOHNNYCLARKE
cliff
Thanks for your advice.
I was thinking of using a black very coarse scrubbing pad on my 16inch scrubbing machine before applying mapei primer G.
Do you think this will do the job?
Have recently started using mapei after meeting one of your reps on apex grange stand at stone show and my guys are really happy with the keraquick for laying ditra /insulation boards over underfloor heating and keraflex maxi on normal heated floor screeds.
Am going to try kerquick on limestone next time round as it seems to give you more time than other brands ive used that go off in ten minutes when mixed with a whisk in warmer weather which is no good for a stone fixer who needs time to adjust stone when laying long courses.
Will start using your fibreplan over electrical heating if it is as good as mira xplan has been for us so far.
ANY STONE FIXERS OUT THERE REALLY SHOULD LOOK AT MAPEI PRODUCTS .
REAL QUALITY ,GREAT TO USE AND APEX GRANGE GIVE REALLY GOOD PRICES WHEN BUYING BY THE PALLETT.
johnny
Branty
Tiling to Anhydrite, is a lot like tiling to finish plaster, with more worries. I.E it wetter, thicker, and has a shinier finish.
Removing the laitance and the shine is essential. Probably more so is checking the moisture content. As Cliff says, You can do all the prep you like, but if there's to much moisture in the screed, the adhesive won't bond.
Your risidual content has to be below 0.5% before you can fix tiles direct to it. I believe you can use ditra if the risidual moisture content is 2%. In both these instances you will need a meter reading if you want to be sure.
It's all well and good your builder saying it's been down for four weeks, if the first two, it was exposed to the elements. Get him to do a moisture reading.
JOHNNYCLARKE
getting a bit confused now.
Mapei and Weber both said I could put ditra down with a rapid flex quickset even if screed only 2 weeks old.
Now presumably screed is still not completely dry.
So Mapei said take skin off top and apply primer G which i think is accrylic.
So any moisture left in screed should go down and sideways if it cannot get up through primer.
Is this correct?
Branty
Is this correct?
The wat I see it, is its all about the moisture. If there's too much in the screed then that has to affect the bond to the ditra no matter what adhesive you use.
If you can get some reading that says its less than 2%, then you can use ditra.
JOHNNYCLARKE
just been to look at job now with a diy dampmeter and it feels and looks damp still after 24 days down.
Screed is apparently 40 mm thick which should mean 40 days to dry.
Dont know what to do as committed myself after talking to the mapei tech guy on friday who said would be ok.
If i put this accrylic primer G down will this stop any moisture from screed coming up or just some?
I thought if it really seals in screed then any moisture would move sideways and up wall which would be fine would it not!
CLIFF IF YOU LOOK AT THIS I WOULD REALLY APPRECIATE MORE ADVICE OR CAN CONTACT ME DIRECT.
I AM DUE TO START MONDAY BASED ON MAPEI INFO BUT NOW IM CONFUSED.
THANKS JOHNNY
Reply to anhyrdrite screeds in the British & UK Tiling Forum area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
anhyrdrite screeds
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
