Guest viewing is limited
Discuss Another Builders bathroom disaster in the Bathroom Tiling Advice area at TilersForums.com.
F
faithhealer
Todays job, Bathroom to make good after builder
Supposed to have had a wet floor but due to water coming up in the opp corner to the waste they turned it into a cubicle! Water still doesn't drain away though, slates a bit rough and not cut into the envelope, builder tried to overcome this by a sheet of mosaic around the drain! Looks awful and doesn't work!
Wedi membrane covers the whole floor and wall but seems to be stuck on 5mm plywood, can move the walls
Used the wrong shade of tile when trying to put right himself
large format tile with tub gear and 10mm thick dot and dab
Silicon around edges is half inch in places with no smoothing out.
grout in one corner is swept in like a sand dune
UFH under his dot and dab, therefore not very many warm spots!
sand and cement for grout at first then he was told to replace cubicle with 'proper' grout
Corners of cubicle have this plastic quadrant coving siliconed on, heavy on the silicon
Cubicle has a box seat with mosaic, not enough grout in so water stands despite fall, some grout actually missing.
Mosaic on ceiling, mismatch galore
grout on wall varies from white to gray
brickbond tiling sucks as well
customer asked me for advice, only one answer really isn't there.
F
faithhealer
At least i recommened a good tiler to sort it then john.... it is as bad you as you said on the blower hey!!..
Did you get some pics mate..?..and were mr and mrs H ok at your findings..?[/QUOTE]
Mr H backheeled it so mrs H was home within the hour, think I'll get a call next year!
F
faithhealer
If he has a 6 month retainer then he must have done a lot more work on the house, did he build an extension or something? retainers can be quite large so there's money in the pot.
Yes CR, extension, building work is pretty good, lulled into a false sense of security when I removed a 'panel to reveal proper copper pipework, with isolater valves, nicely parallel and clipped, nice crossover past the waste! short lived!
doug boardley
Reply to Another Builders bathroom disaster in the Bathroom Tiling Advice area at TilersForums.com
Hi all Interested in views from the trade world about how I should deal with a big floor tiling...
2 3 4 5 6 7 8 9
41K
This was installed by a so called tiler/bathroom fitter. As you can see it was all ripped out...
diamondtiling
Hi, So I've got to the end of the main chunk of the work... finally... and it's looking pretty...
Qwerty
Q
Hi all - just come across this site and congrats to all for the great advice supplied to all -...
devillindaf
Unsolved
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
