2020Tiling
Can you recommend one that could cope with 600 tiles and over and handle type?
The most popular cutter is the 3C2M 74cm MAX cutter. Max is a push handle that is easy to use. powerful breaker that will cut up to 20mm porc but at the same time do ceramic, glass, mosaics etc..etc..All our cutters are built from start to finish in Italy by hand so you get what you pay for.Can you recommend one that could cope with 600 tiles and over and handle type?
Do you mean somethink like the Rubi way of cutting....
Sounds like you have 2020Tiling.....
If your up north then why not call into westerhope and have a play on his sigma machines.
Hi there, received my new 3C2M Max cutter from Tradetiler after reading recommendations on the forum. Although the machine cuts OK, I have a problem with the measuring bar. The fixing pin is not dead on center of the scale. So when I cut with the guide on the left I get accurate cuts but when I switch it to the right my cuts are out by between 1mm & 1.5mm. This is a pain if I forget to allow for this as I have to cut another tile. I would like to know whether you guys consider that within tolerance or if mine is faulty?
