Discuss Anyone seen this happen? glass mosaics losing the backing after tiling in the Canada Tile Advice area at TilersForums.com.
Rizzle from the Portizzle
some times its as simple as not back skimming this leaves air trapped leading to oxidization between
the/ backing/ adhesive/air trapped/ cement adhesive creates heat as it drys uneven drying will create hot and cold spots on back painted tiles this is what can happen
One Day
I once fixed a 20+sqm travertine floor using Toppfix white rsf (Palace).
It hadn't even begun to set after 24hrs and I had a water-stained floor as a result and an unhappy customer.
Palace were not interested in even talking about it. Thankfully Topps rectified it.
Never used it since around 2008 and won't now.
GoneGuy
Just a quick update.
Palace adhesive Rep was in the tile shop and the answer they gave was.
"The white palace adhesive is ok to use on mosaics but they cannot garantee it working as mosaics are made abroad and they do not know what materials are used to bond the back of them, and also it depends what is on the wall aready, we suggest using palace tub adhesive as it has no acid in it that could react with the mosaics".
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
Thanks for the update. What's happening to these tiles then now?
GoneGuy
I've been given replacement mosaics, palace are not playing ball.
So when I get a chance to take them off and replace I will take a few pictures and post them.
Also I will pick everyone's brains for best adhesive to use to put the new ones back up.
Thanks for all the help guys
Reply to Anyone seen this happen? glass mosaics losing the backing after tiling in the Canada Tile Advice area at TilersForums.com
Hi all just got back to tiling my bathroom after suffering with a slipped disc since the start...
Hi Guys, I had some mosaics installed the other week and seeing some very odd discoloration on...
Hello, I am hoping I may be able to get some advice. 2 years ago we had a new kitchen fitted and...
Hi , I am about to start my tiling project, it's quite large at 60m2. I have underfloor heating...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
