jay
The way its reading is it wont deteriorate if moisture gets in to it like plaster does the last link says that be interested how Bri goes with that test
Discuss aquapanel in the UK Tiling Forum area at TilersForums.com.
Jay when you ask aquapanal and hardie do you still need to tank showers after using their board they both say yes so i believe that answers the question :juggle2:
AQUAPANEL® Cement Board by Knauf USG Systems | home en says it is 100 percent waterproof here
i have a sheet lying outside and has been for a few months round back of my hut and also a part sheet of hardi
the hardi has started breaking down but the aquapanel is still solid,for me thje hardi is more of a fibreboard and the aquapanel is a particle board they are of 2 different constructions
i have been using the aquapanel on floors for a fair while now and i use there 12mm sheets on bath panels.....if im doing shower areas i use plasterboard normally and tank it simply because the plasterboard is a more versatile product and can be used for dot dabbing onto block etc.
a great product aquapanel,i think they also do an exterior particle board as well
Reply to aquapanel in the UK Tiling Forum area at TilersForums.com
