Discuss Are my expectations too high? in the Canada Tile Advice area at TilersForums.com.
Geronimo
Hello,
To cut a long story shirt, a while ago I employed a professional tiler to tile a floor and wall. Unfortunately the work was well below satisfactory. I pursued this matter via the legal route and was successfully in obtaining a full refund plus compensation. I had the work completely re-done and this time I chose a registered TTA tiler. The wall work is very good however I have a few issues with the floor and wondered if my expectations are far too high. The concrete floor was primed and levelled prior to fixing the tiles. The the tiles are level however there are some places where I still have tiles lipping. This was a massive problem in the first job something of which the TTA tiler was well aware of when he came to inspect the previous works. On the whole the job looks good from a standing position therefore I dont know whether to contact the tiler or not for his opinion as I do not want to appear disrespectful or critical of his workmanship, however I find it difficult to comprehend as to why I still have tiles lipping in certain areas 1/1.5mm 2mm in 1 area. 20sqm of floor and 5 sqm of wall took around 5 and half days at just under £1100 including material (not tiles). I have inspected a number of tiles myself and I do not see any signs of warping. I would be much obliged if you could advise whether my expectations are too high, or get the tiler back out to rectify, however I do not want to hassle and stress of my previous experience. Is this work industry standard and would be recognised as so by the TTA?
Many thanks in advance.
  • Images_Layout 1.pdf
Colour Republic
The floor certainly isn't terrible but not perfect. The grout looks a little too shallow for a start.
Before judgement could be passed you'd need to ensure the tiles are perfect and not curling in the corners, place a few face to face on each other, then inspect each corner to see if they meet.
If the tiles are slightly warped or cupping then it's almost impossible to get the floor perfectly flat, although large grout joints like that should hide some minor defects
I
Ian
From looking at the pictures it looks like the tiles are bowed, in some of the pictures the lips are only evident in the corners, along the length they look lip free. If you have a couple of spare tiles, put them face to face, are they straight?
Sent via Tapatalk for iPhone 5
Peter
Reasonably standard looking job, but interestingly it shows that just because you're a TTA member you're not necessarily a better tiler than a non member. As said, check the tiles aren't bowed as you can't make a perfect job out of curling tiles. 5.5 days seems excessive, 3 days would have been plenty imo even with levelling the floors first.
Certainly isn't the worst job ever done. It could be better.
But for the £44 a metre you've paid, I think you have every right to at least have a chat with your tiler & see what he thinks.
If the tiles are slightly bowed or something, the tiler should've noticed as soon as he started fixing them
Colour Republic
it is of no consequence how much he charged or how long it took job to be completed
It kind of is though isn't it. £44 a meter for ceramics isn't excessive but it is a rate at which you can expect a little extra care and attention. If the OP had come on here and said 'I paid £100 for the lot we'd all be saying you've got a bargain so stop picking'
If the tiles are bowed then maybe the tiler should have advised the client that the floor will look ok but won't be perfect, if there isn't anything wrong with the tiles then maybe the floor isn't up to scratch... unless it's 1 lipped tile taken from 20 different angles :lol: In which case it should be replaced
Time's Ran Out
If it's the same quality tile at the 2nd time of asking then perhaps it is an issue with the tiles!
There is only 1 photo from distance and although I wouldn't want to pass comment on the quality of fixing from a few selected close ups, it's a bit like statistics - you can use them to illustrate any point!
In my humble opinion, you are never going to please everyone all the time, so show some metal and raise your concerns with the tiler involved and I'am sure he will be happy to discuss your expectations.
Good thread and thanks for posting.
Reply to Are my expectations too high? in the Canada Tile Advice area at TilersForums.com
I have had my ensuite and bathroom installed in April. The job had ongoing issues during the job...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
