charlie1
Its been a while but just so you are all aware having spoken to the TTA it appears that technically a lip on a floor tile can be as thick as a pound coin 3mm.
Flatness and variation from plumb:
± 3mm under a 2m straightedge.
I was told if I used a 2m length of wood with a pound coin under each end, the floor tolerance can technically drop by 3mm or raise by 3mm to touch the straight egde.
Last weekend I have took the bath room tiles up my self and refitted them, I have used a metal rule across each joint to elimainate any height difference/lippage, whilst ensuring each tile sits level. I just find it difficult to comprehend why a tiler registered with the TTA was not able to achieve the same. If you want a job doing and doing well........., now I just need to make the best of a bad situation by replacing individual tiles. Very dissappointed. 😱(
I dont know what you do for a living but you have the makings of a good tiler!
