I use tanking membranes...lot less fussy than solution kits and no worries about getting the correct tanking thickness etc..
..100% water tight first go..
Thanks for this, as I said in my first post here, had I found this forum before I would of done things differently and using a sheet membrane would of been one of the changes
The other may have been not using multiformat porc tiles on the floor with an offset drain in a 1500*800 shower area, I thought I would have to marry my tile cutter as I was seeing her so much!:smilewinkgrin:
Also Dave, cheers for the instructions,
but again they make no mention of second-coating which brings about my concerns with doing it.
Whitebeam
, Agreed, that's how the info from Bal reads
CR Yes agreed, maybe a conversation with Bal on Monday would be the best bet! To be honest I'm happy with the floor especially as the matting gives the ability to ladle on two thick coats, so I'll tile that today and deal with Bal and a possible second coat to the walls tomorrow.
Yes this job is for me, though I have a loft extension to build for a client next year and they were thinking of having a wet room as an ensuite so this is valuable experience. Additionally I have my ensuite to tile too yet so guess I'll be getting more practice.
Stan001, Thanks!
Yes I was definitely getting the first coat try to lift off, or indeed bead bits of rubber off, when I tried to retouch the lighter areas after a few minutes so I gave up that a course of action sharpish. I think my problem was definitely using a brush rather than a trowel, however what put me off trowelling was the ball-ache of getting it onto the trowel without covering a hawk or the like in gear. Your suggestion of brushing it on with a fencing brush and then trowelling makes perfect sense! God why didn't I think of that:mad2:
I can't believe they would want to use a roller with this gear either, apart from the edge coverage issues the splatter would be something else surely, no matter how slow you moved it.
Guys, Thanks for all of your help with this, really appreciated!
Cheers,
Steve
