Bath shorter than room width
sorry mate just read your post
if you have already tanked etc and dont want to sheet over etc you could frame over the some of the area(doesnt need to be to ceiling height, you could do 300mm up the wall above bath level to form a cill for sher gel etc) and sheet over with aquapanel(this is water resistant)
that YouTube video was interesting viewing Polishtradesman :thumbsup: but i would guess you meant "insulation" not "isolation" 😳
unfortunately framing above it is not an option either as it would look dam ugly to see that from the side. when you open the bathroom door you will be looking straight at the bath from the side, not the ends. unless there are any massive objections i will push for the neatest looking and fit the bath into the tiled area leaving 1-2mm to Silicon.
that YouTube video was interesting viewing Polishtradesman :thumbsup: but i would guessyou meant "insulation" not "isolation" 😳
1-2mm gap to Silicon sounds fine to me mate, as long as its water tight! :thumbsup:
My english is not good enought to write exacly what i mean. I dont know diffrence between insulation and isolation, i wrote about foam (same like one to fix windows, door etc) which make sound isolation so if you bang the bath you will not hear loud sound. Method with this material makes bath solid and it looks very nice after tiling this cover.
wheres the access panel polishtradesman for possible leaks on the waste in the future
Of course you need to do acces panel. You need to cut hole in right place and fix metal door and use silicon to fix tile to door.
Featured Threads
