Bathroom project - Work in progress
davemul
Apologies mods of this needs to go elsewhere.. please feel free to move it or bin it!
Riiiight.. here goes....
We've been in our first house nearly 2 years now. We've (well ... more like I'VE!) done everything else bar the bathroom. It's an old 1800's cottage so the bathroom was in a pretty bad way. Solidly built but nasty and OLD!
I decided a few weeks ago to RIP it out and start from the beginning.
First task was to move the hot water cylinder from in the bathroom to a new cupboard outside the room (thanks to Scruff from ultimatehandyman.co.uk for the advice!)
Now you see it...
Now you dont!
Ive taken quite a lot out..
CARNAGE
Well, I picked up a load of bits today..
Marmox goods and tiles!
New shower pump for the house too
Also have taken delivery of a taptile wireless light switch system Taptile - Ditch the switch one-touch mood lighting and dimming solutions for the bathroom and kitchen
6 astro glass downlights
an airflow icon15 extractor fan
and some Polk RC60i ceiling speakers
and a couple of remote water isolation switches about surestop
More bits arrive tomorrow.. i'll update this thread as I go along... im taking next week off to start the plumbing and install!
Good one..
I was slightly concerned when i saw the pic of the underside of the tray with the cut-out for the pipe that it might of been foam cored as per the Showerlay tray and would need full support.
Look forward to seeing the ongoing pics :thumbsup:
Started to plumb the shower pump and flow sensors for the dry deck today. Better not leak!
did some plumbing for the shower mixer and some electrics also... more pics tomorrow
this bathroom lark is stressful!
Pushfit for ease in my situation. I'm only using compression where its a last resort and im no plumber so am not going near solder! 🙂
Only problem is copper pushfits are so expensive! I reckon ive spent £800 in fittings and pipe alone so far!
I either use a local plumbers merchant for speedfix (plastic) or B&Q trade section if I am out of town for similar prices.
I use speedfix on copper pipe - I'm NO plumber either, but I'm insured and I know what I'm doing - kind of!
(Those copper pushfit are about four times the price of speedfix at a merchants)
Riiighty ho.... Today I have been a proper bender!
Pipe bender that is!
Shower mixer/thermostat hot and colds are fully plumbed from the new pump
Shower head fitting is also plumbed
Tomorrow i'll route the pipework for the bath taps, cap them off and then turn the water on and try and fix all the leaks!
bit concerned with the shower mixer but I used a good few loops of gas ptfe tape on the screw in unions and they went in pretty tight so fingers crossed!
and the mess that is my desk.. where I try to work things for this damn bathroom out! oh and ask questions to you kind folk on here of course!
Finally, all the plumbing / re routing is finished. It's all tested too. Shower turns pump on, no leaks anywhere (touches wood)
Pipes done, just sorting some extra wiring / tidying up the old stuff too. Previous installer had it running everywhere and not clipped anywhere!
insulated the hot water pipes too. Have left the cold and shower waste pipes. Had to add a few noggins to support the edges of where the plywood will meet and the perimeter of the marmox wet room tray
Next I layed some insulation in between the joists. Not over any cables now they have been tidied up and clipped to the joists. HOW ITCHY! very itchy!
Started to prime the underside and edges of the WBP ready to lay
WBP now fixed. Every 150 centres. Used a lot of screws!
Most of the electrics now in, apart from some final clipping, I should be ready to test / set up the dry deck once ive fixed the wet room tray/gulley. Added a light in the cupboard aswell that comes on when door opens as it was getting dark in there!
next step.. laying the marmox boards and tanking!
Bathroom Tiling Advice
Unsolved
davemul,
davemul,
