Bathroom project - Work in progress
davemul
Apologies mods of this needs to go elsewhere.. please feel free to move it or bin it!
Riiiight.. here goes....
We've been in our first house nearly 2 years now. We've (well ... more like I'VE!) done everything else bar the bathroom. It's an old 1800's cottage so the bathroom was in a pretty bad way. Solidly built but nasty and OLD!
I decided a few weeks ago to RIP it out and start from the beginning.
First task was to move the hot water cylinder from in the bathroom to a new cupboard outside the room (thanks to Scruff from ultimatehandyman.co.uk for the advice!)
Now you see it...
Now you dont!
Ive taken quite a lot out..
CARNAGE
Well, I picked up a load of bits today..
Marmox goods and tiles!
New shower pump for the house too
Also have taken delivery of a taptile wireless light switch system Taptile - Ditch the switch one-touch mood lighting and dimming solutions for the bathroom and kitchen
6 astro glass downlights
an airflow icon15 extractor fan
and some Polk RC60i ceiling speakers
and a couple of remote water isolation switches about surestop
More bits arrive tomorrow.. i'll update this thread as I go along... im taking next week off to start the plumbing and install!
Fixed the entrance by replacing knackered boards with 18mm ply.. the fein has been a lifesaver during this project!
Also measured and cut the marmox backer boards. Just need to mark where the pipes/cables are then its adhesive time!
Thanks mate
just finished sticking down the boards and screwing... PHEW is all I can say. Went pretty well. Just letting things dry.
Might change career the way i'm going! 🙂
Hi Dave, nice job mate. I cant wait to see pics when its done, I'm especially looking forward to seeing the glowing toilet flush button.
Grohe gear is top notch but damn expensive, worth the money though.
Is the bath mixer fed from unbalanced feeds? eg cold from mains and gravity hot, if so dont forget the non return valve on the hot to prevent cold entering the hot water system, which it will because of the higher cold pressure. It will push hot water back into the cylinder and back up into the loft tank and then pour out of the overflow. Granted it will only do this when your using hot and cold together, or if it develops an internal fault.
Many a young plumber has been caught out with that one, they keep replacing ballvalve washers but cant understand why the tank keeps filling!
Make sure you use the low pressure flap type or it will restrict the flow. Get them from BES Plumbing.
Plumbing Supplies | BES Gas & Plumbing Fittings Part 7463
Hi Bob, thanks mate 🙂
Cold feed to the bath is from the water tank in the loft (which then goes on to feed the pump then on to the shower). Hot water cylinder is also fed from a tank in the loft too mate.
Sound ok?
oh and i bet you are all TOTALLY fed up of pictures of the floor, so the last ones for the time being. All stuck down with SPF and screwed with washers as I went along. Also Sealant in between each board. Will tape then paint with mapegum later.
Bathroom Tiling Advice
Unsolved
davemul,
davemul,
