Battens.
  • Thread starter Thread starter Paul Sh
  • Start date Start date
  • Tags Tags
    usa
well done some research on tinternet and found out a batten is a sea going term when they tiled on board the old pirate ships, hence the term "batten down the hatches "( hatches been an olde english word for large format tiles)
hope that ends all confusion:wub:
Paul.....use a batten if it makes your life easier mate, once you get going you will learn how to go without them. Iuse a batten if fixing heavy porcalain etc.
Some of the quality adhesive out there is non slip so you can just fix a load to the wall where your starting point is then level em up with your bubble, after that it's just plane sailing mate.
TJ
I do use a batten on my mrs though
NICE 1 l&r,PAUL you will need to get used to L&r m8.
I did have achuckle at Pauls technical data tho.lol:whatchutalkingabout :whatchutalkingabout
In 20 years tiling can hardly remember a wall flat and straight enough to stop a standard size wall tile from slipping with normal suction.MANUFACTURERS USE THE TERM NON-SLIP FAR TO OFTEN!! It makes the tiler think that the tile will hit the wall and stick like velcro, don't be so nieve,walls bend and have hollows all over them so to get a good straight finish,adhesive is thicker than just a scraped notch onto glass,slipping will occur and when it does you cant claw the level back.Using battens gives you a great first course which is the foundation and backbone of your wall tiling job,if you can't be arsed then be it on your own head if the course over the bath looks like a smile 🙂or a frown:sad_smile:
Very true Gaz, it really pisses me off how they say it's non-slip when it clearly isn't!! unless your walls are ultra straight you aint got no chance.....
never had a straight wall yet but when i do i will have an ******:angel_smile:
battens are fine just be aware of what might be behind wall when youre screwing em or nailing to wall, dont want to bust anything naughty like pipes or wires
tony
tony
Top tip there mate,have a metal detector or use hot glue gun to put up! a claw hammer under batten pops em straight off
Just today i saw a hot glue gun and was thinking it'd be useful to stick a batten ; )....its safer than nailing into a pipe or wire...might try it out...
Battens.
Tags Tags
usa
Paul Sh,
lm tiles,
Paul Sh,
lm tiles,
