monty
Hello
Just thought I'd pass on a few guides that I've read over the last few months and thought they would help the tilers just starting out.
For the more experienced tilers it will be bread & butter but I'm sure you will correct them if you don't agree (as it's only a guide) or add to them.
Well here goes with the first one.....all this info is from weber tiling soutions handbook... http://www.netweber.co.uk/tile-fixing/find-the-right-solution/problem-solutions.html
Substrate diagnosis
8 key points to check....
1. How to check the flatness of the substrate
The flatness of the substrate should be checked with a 2 m straight edge mounted on 3 mm spacers.In the case of direct bonding of the tiles, any defects should not exceed - + 3 mm (IE high points not touching and low points no more than MM below) under the 2 m straight edge.
2. How to check the hardness of the substrate
The substrate must be both hard and resistant in order to avoid cracking or disbanding at a later stage.
* Check the surface hardness by scratching it with a pointed tool in several places.The scratch must be superficial.
If the substrate is not hard enough, it must be removed until sound material is reached.
* Plaster walls should be brushed with a stiff brush and then wiped to remove any loose material.Also check the in-depth of existing screeds or plastered walls.
3. How to check the stability of the substrate
* This check mainly concerns wooden floors laid on joists or battens, wooden panels and, more rarely, partitions.
* The flooring panels or strips must not move when walked on.Partitions must not flex when pressed by hand.
If this is not the case, reinforce the floor with noggings between the joists and replace the boards. Brace unstable partitions.
4.How to check the porosity of cement-based substrates
Cement-based substrates must have normal absorption in order to avoid premature water loss from the cement-based adhesive and to ensure that the bond can develop correctly.
* Pour a little water onto the substrate
* If the water is absorbed in less than 1 minute the substrate is considered as excessively porous and requires priming.
5. How to check the adhesion of the excising covering
* Check the adhesion of existing tiles or rigid floor tiles by tapping with a hammer.
* Any hollow sounding tiles or tiles with poor adhesion must be removed and replaced by similar tiles or the substrate reconstituted with the appropriate product.
* to check the adhesion of existing paint carry out a cross-hatch test using a suitable knife or cutter.Emulsion paint is not suitable for tiling over.
* Score the paint in small 2 x 2 mm squares over a total area of 10 x 10 cm.
the paint is considered suitable for tiling if 80% of the area of the small squares remain bonded.If not, the paint must be removed mechanically.
6. How to clean the substrate
* Eliminate any traces of plaster with scraper. Carefully remove any dust and then apply suitable primer, if necessary, on existing tiles,, paint, wood or vinyl tiles or appropriate primer on cement or gypsum-based substrates.
* If the existing floor covering has been removed, eliminate any traces of adhesive so that no film residues remain, only residual coloration of the substrate.On acrylic or neoprene adhesive residues carefully remove any dust and apply suitable primer.On bituminous or epoxy adhesives apply appropriate primer.
* On concrete, remove any residues that may affect the adhesion, such as superficial free lime or traces of oil, using high pressure cleaning, sanding, abrasive cleaning, etc.
7. How to check if the substrate is dry
* Plaster substrates must not have more than 5% residual moisture during application (depending on the ambient conditions, a plaster finish reaches this level of dryness from 2 weeks to several months).A minimum of 4 weeks drying time must be allowed prior to tiling.
Anhydrite screeds must not have more than 0.5% residual moisture before being covered.
Cement/sand renders and screeds must be left for 2 weeks and 3 weeks respectively prior to tiling unless special fixing methods are employed.
8. Priming
* Gypsum plaster should normally be primed before applying a tile adhesive.If the adhesive is cement-based, it must be primed with suitable primer.
Anhydrite screeds must be sealed with suitable primer before applying any cement-based product, leveling compound or tile adhesive.
Substrate diagnosis
8. Priming
