Best Adhesive To Fix Porcelain Tile To Ditra Over Plywood With Underfloor Heating
Talked a customer out of Polypipes spec on same in January, went straight down on pipes and insert boards instead as I couldn't get my head round tiling on the ply..
ardex af200 onto ply. Couldn't be easier!
As Impish said......Ardex AF200 to stick down the Ditra. You can then start tiling straight away.
If you use rapid (remember you must use rapid onto ply) then you have to wait for the adhesive to harden before you walk or tile onto the Ditra.
If you use slow set to tile porcelain tiles onto Ditra then give it a few more hours drying time.........this especially applies in the Winter time.
I'm using rapid to bond the ditra it's gonna be laid Wednesday and possibly Thursday then start tiling Saturday so it's got plenty of time to cure
What would be ur preferred method of goin over polypipe ?
HardieFloor for under floor heating
For clients who desire the comfort of under floor heating, HardieFloor® is the perfect solution. Unlike wood, it won’t swell, shrink, expand or buckle due to temperature changes and its thermal conductance properties mean that the heating system will react faster and can help conduct more heat into the room.
Are u talking the real thick board with the lip that lock together?
Why do you have to use rapid only on ply, or wait for adhesive to dry before tiling?
Kyle Knowles,
J Sid,
Kyle Knowles,
J Sid,
