Discuss Best construction/prep method for bathroom floor? in the Bathroom Tiling Advice area at TilersForums.com.
peterparker
Hi there
I'm new to the forum so please bare with me. I am having an en suite shower room fully tiled with electrical ufh, it used to be a bedroom. At the moment there are just joists, the boards are shot so will be going in the bin. It's quite a large room ie 3.8m x 2.7m.
What I'd like to know is the best way to construct the floor from the joists up. Cost is not an issue, it has to be a perfect job which lasts.
I've read lots of historic posts and know that I need some combination of 18-25mm wbp ply, hardie backer, insulated board, ditra matting, latex, flexible adhesive etc.
I just need to know the exact order they go in etc.
Thanks in advance for your help
Chalker
1,058
Tadcaster
My 10 penneth.
make sure joists are level and flat.
put felt on any pipes to stop creaking.
glue and screw noggins at 450 or 18 inch centres, depending on ply size.
glue and screw 18mm exterior grade ply.
prime boards.
Fit insulation boards with SPF and screw with washers.
tile using SPF
or fit backer board and tile.
peterparker
My 10 penneth.
prime boards.
tile using SPF
Thank you for taking the time to reply, may I ask you a few further questions please?
1) If I use rock wool between the joists is this as good as insulating board? I'd be keen on rock wool as it will provide some sound insulation as well.
2) Some people suggest using 'latex', is this just an additive in the SPF?
3) As belt and braces I might as well use ditra matt, should this go on top of the backer board and then UFH on top of that?
4) Shall I tank the wet areas and if so do I apply the tanking paint directly to the ply?
Thanks again
Chalker
1,058
Tadcaster
Should ply used onto joists as flooring not be structural ply rather than just exterior grade? Some exterior grade ply isn't very good with voids etc & may not be up to being used a flooring as opposed to just over boarding.
With plenty of noggins its fine. Try deforming a 450x450 piece . Better would be 22mm on a larger floor, but I've never (yet!) had a problem, as long as it is good quality ply. Not from the sheds, there is a massive difference in quality. Best purchased from a good timber merchant.
peterparker
In question 4 I see you asking about tanking ply?
Is this ply on the floor or is it on the walls?
Hi Stef
I'm talking about tanking ply on the floor, there is no ply on the walls. Two of the walls are external ie brick/block construction, the third will be covered in backer board and the fourth will never see any water.
Stef
Hi Stef
Personally I would overboard the ply with a backerboard, use an insulation board & tape the joins & it will be waterproof & no need to tank.
Reply to Best construction/prep method for bathroom floor? in the Bathroom Tiling Advice area at TilersForums.com
Hi guys, I'm new to tiling and looking for some advice. I'm practical and usually pretty good...
I've gone cross-eyed reading threads on here trying to work out how to get my bathroom ready to...
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Hello everyone, I tried to avoid asking this question as I'm sure you're all sick of seeing...
5K
Hi guys! Right, so I'm starting this job next week (I'm the builder as you know!) so I need to...
Unsolved
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
