Discuss Brickbond in the Canada Tile Advice area at TilersForums.com.
As a rule we go by this when selling, something we got sent a good few years ago.
Planometric Tolerences
With the increasing popularity of large format wall and floor tile we wish to remind you that the tolerances allow for a 0.5% warpage in tile planarity. therefore the european norms allow on a 60x60 tile 3.5mm tolerance between the centre of the tile and its corners.
This causes no problem whatsoever when the tiles are fixed in the normal draughtboard patern, however, it can create problems if the tile is fixed brick bond or half bond particularly in the case of rectified tiles when the joint width is reduced to 1.5mm. It is advisable in this instance to ask your client to check for acceptability BEFORE fixing or alternatively to consider bonding 1/3 - 2/3 which will have the effect of halving discrepancies in planarity.
Reply to Brickbond in the Canada Tile Advice area at TilersForums.com
Good morning I’m tiling a bathroom in 600x400 porcelains both floor and wall, ideally it want to...
Good morning I’m tiling a bathroom in 600x400 porcelains both floor and wall, ideally it wants...
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Hi there, Im a DIY tiler and am about to half height tile my downstairs toilet with 600x300...
Brickbond
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
