Hi
Let me just give a brief history.
House built in 1999.
Bathroom installer fitted new bathroom and ensuite in 2010 and did not do it properly.
One of the problems was the showers, which I have stripped and rebuilt.
The original shower trays had been fitted with plastic legs so when I removed the showers I built a wooden base for the showers, picture 001 and 002 show some of the construction pictures.
The marine plywood that you see in the pictures is 20mm thick. The marine plywood was glued and screwed to the original chipboard flooring.
You can also see the floor tiles in the pictures next to the marine plywood.
Picture 003 shows the floor tiles that need to be removed.
I want to avoid replacing the original chipboard flooring, as it will weaken the chipboard flooring that the marine plywood is on for the shower tray base. I am also not sure if it will weaken the chipboard flooring going into the bedrooms and hallway.
In terms of the floor being solid when I step on the tiles, the only slight creak I get is on a couple of tiles, which are next to a few tiles that I replaced because those were chipped. When I removed those tiles I used a chisel and hammer and then a multi tool with a carbide rasp to sand the tile adhesive. It was then that the other couple of tiles slightly creaked.
I was going to use a SDS drill and chisel bit to remove the rest of the tiles unless someone had an alternative?
There are too many problems with the main bathroom and ensuite that have been bothering me for four years. I have been giving serious through since October to carefully remove the toilets, sinks, bath and radiators to use again and then to strip and rebuild, but not removing the shower walls, as I fitted cement boards when the wooden base was built.
I would use moisture resistant plasterboards for the rest of the walls, cement boards are great for the shower area!
All the tiles are ceramic in the main bathroom. In the ensuite the tiles are porcelain at the moment including the floor, but I would like to replace them with ceramic as they are easier to work with. The ensuite floor tiles I would also be looking to remove but not until the main bathroom is done.
But before I can go ahead with everything else, I need to find a solution to how to retile the floor.
Just to mention height of the floor is no concern and I do not mind having a step.
I can use crow bars and lift the plywood up, but I’m sure it will leave the chipboard flooring in a mess.
I know I mentioned I could fix and glue plywood or cement board onto the existing 6mm plywood and some people said no, but can I ask just for my own knowledge, what is wrong with that?
Anyway hope the above information helps.
