rj1884
Good afternoon
went to look at a job this morning. 4 upstairs bathrooms including a loft extension bathroom and all of the floors are the wonderful 22mm moisture resistant chipboard straight onto the joists. All the floors are solid so no deflection issues. It's been explained that it needs overboarding which he understands. My question is, is if I use hardie backer or an insulation board like marmox glued and screwed am I right in thinking that it's really only the screws holding the board down as the adhesive doesn't adhere to the chipboard or am I way off the mark.
Also what would you guys recommend using in this situation.
Thanks in advance
Thanks in advance
