Discuss concrete sub-floor with ply strip running across..............decoupling membrane? in the UK Tiling Forum area at TilersForums.com.
aflemi
Doing 3 rooms in apartment block, all have carpet on lino tiles on bitumen on concrete.
Planned to remove as much bitumen as poss using heat gun + scraper, sugar soap clean then slurry coat 50/50 SBR/rapidset flex (mapei/tile giant proflexible).
Problem is 2 rooms have a 180mm strip of ply which is well screwed down, no flex separating concrete. This obviously runs across the whole apartment.
In 4m x 2m kitchen the strip runs across the 2m width about the middle.
In one bathroom it's about 70mm into room.
Laying full bodied porcelain tiles no ufh. Do I need decoupling membrane or would keraquick with latexplus do the job??
aflemi
Re: concrete sub-floor with ply strip running across..............decoupling membrane
The only thing I can think of with the ply it has pipes running underneath for access
Correct mate, on further investigation 25mm ply covering pipe channel in concrete. So on the upside it's the same slab of concrete but how will heat from pipes affect things assuming happy with deflection factor..........?
Rich
Really you should have expansion joint in the tiles at every joint between ply and the screed even if it is deflection free but of course that would look awful. Hmmm... Have you had the ply up? Any chance of filling the channels in? It wouldn't be ideal but I would feel better tiling over a channel that had been filled in rather than a hollow channel covered in ply.
Reply to concrete sub-floor with ply strip running across..............decoupling membrane? in the UK Tiling Forum area at TilersForums.com
Hi guys, First time posting on a forum but cant seem to find any advice that is matching my...
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Any advice gratefully received on tiling a concrete screed that is according to the builder not...
TJ Smiler
Hi I am laying 14 sqm of 12-15mm sandstone tiles onto a concrete 1930's floor. DPM is unknown -...
6K
matty
E
Hi, this is my first post here, hopefully of many. I have been doing most of my own DIY on my...
Qwerty
Q
TF Group Please Join
aflemi
