Rolandk
Hi,
just been checking on adhesives and a bit confused!
I have a concrete substrate (coarse and lumpy and the more I sweep it the more loose material it releases!) Also need to tile over a small amout of green chipboard. Electric UFH going in too. Plan is to SBR prime the concrete then board over the concrete and chipboard with 6mm Marmox boards. What is the best adhesive to use to stick the boards down to the 2 different substrates? I was going to screw down to the chipboard as well. Then the correct adhesive for porcelain (300mm x 600mm) tiles onto the Marmox? Total area around 30 sq m.
Was going to get Mapei products?
Thanks,
Roland
Thanks,
Roland
