JOHNNYCLARKE
THIS SEEMS TO BE A RECURRING PROBLEM.
ANYONE GOT ANY VIEWS ON BEST PRECAUTIONS TO TAKE OR WHICH PRODUCTS TO USE.
90 % OF SCREEDS I LAY LIMESTONE ON HAVE WATER FED UNDERFLOOR HEATING.
EVEN WITH THE FIBROUS SCREEDS THAT ARE OFTEN USED THE SCREED STILL CRACKS AT WEAK POINTS IN DOORWAYS.
BUILDERS ON DOMESTIC JOBS ALMOST NEVER PUT EXPANSION JOINTS IN SCREED AS THEY SHOULD EVEN THOUGH I ADVISE.( SO I AM COVERED)
I ALWAYS TRY TO GET CLIENT TO HAVE DITRA MATTING BUT ON FLOOR AREAS ON AVERAGE BETWEEN 30 - 80 SQ MTS FOR A KITCHEN /BREAKFAST AREA PLUS OTHER AREAS THIS ADDS UP TO A LOT OF EXTRA MONEY.
IN LAST YEAR, TO SAVE MONEY ON PUTTING DITRA OVER WHOLE AREA I HAVE STARTED JUST PUTTING DITRA UNDER TILES THAT GO THROUGH DOORWAYS OR WHERE I CAN SEE SCREED HAS CRACKED AFTER ABOUT A MONTH BEING DOWN.
THIS MEANS OF COURSE THAT I HAVE TO CHANGE ADHESIVE BED HEIGHT IN THESE AREAS TO ACCOMODATE 4MM DITRA WHICH CAN BE AWKWARD OR GRIND 4MM OFF THE BACK OF STONE.
HAS ANYONE EVER DONE THIS AS WELL??
HAD ANY PROBLEMS?
SCLUTER SYSTEMS WILL NOT GUARANTEE DITRA DONE IN ISOLATED SPOTS LIKE THIS .
i HAVE NOW FOUND A PRODUCT CALLED PECILASTIC MADE BY PCI. THIS IS ONLY 0.8MM THICK AND MEANS I DONT HAVE TO GRIND BACK OFF TILES.
HAS ANYONE USED THIS EXTENSIVELY AND HAD NO COME BACK PROBLEMS?
IT SEEMS THE IDEAL SOLUTION COZ IT WAS CHEAPER THAN DITRA OR BLANKE UNI MATT.
DITRA HAS COME DOWN IN PRICE ALOT OVER LAST 4 MONTHS AND IVE FOUND A PLACE THAT SELLS IT FOR ABOUT £ 5.00 PER SQ MT IF YOU GET TWO ROLLS OR MORE.
ANY INPUT ON THIS WOULD BE HELPFUL.
THANKS JOHNNY
HAD ANY PROBLEMS?
THANKS JOHNNY
