Thanks I’ll give it a go. I think when I tried it was tricky to hold the tile still enough to be accurate from both runsI'm confused. The dewalt will cut 760mm when plunge cutting - can't you just flip the tile to cut the rest from the other end? It's not like the tiles are wide and will foul the arm.
Hey @martin1c , thanks for adding that.
Got to admit, the AkKumax is a great blade, I use it on corded too. 😀
It was that bloody Impish fella who put me on to it, good shout tho.
I was inspired by your filter set up Martin, but I bought a 300mm air mover instead, it’s also got a 5m hose I can shove out a window, works well.
Can’t find an image with the hose, but here’s the air mover.
I’ve moved on now tho, still got the extractor if I need it, but recently bit the bullet for this, gotta say, it’s bloody marvellous.I've got one of those too Marc. It's the absolute best if the window opening is big enough. The last few jobs have been smaller window openings. I find the 5m hose ok but but have to keep the first metre straight otherwise there's a fair bit of blow back.
Twin 1200w motor with option to add a third!
32A supply is only draw back if you like, but definitely worth the investment.
I do try mate I do try.Now that's impressive!
You clearly live in a dust free world
