Discuss cutting tiles with a grinder in the UK Tiling Forum area at TilersForums.com.
Always worth having a small grinder about to make cuts.
This is ours.
To put a plug socket in we drilled out the corners from the front of the tile. So that it guarantees the blade will not run on.
Cut the front of the tile with the grinder
Pop the socket in. Perfect fit every time. Works on Large format porcelain tiles.
Equipment used
1x angle grinder
1x battery drill
1x bathroom fitters kit
Selection of seven diamond core drills in five sizes
Reply to cutting tiles with a grinder in the UK Tiling Forum area at TilersForums.com
