Discuss decoupler matting in the Australia Tiling Forum area at TilersForums.com.
K
kevinz3
hi guys
cheers for info , another query , i am laying nu heat lo pro upstairs , and the board is gypsum based , but the pipes on the large runs are stuck to a plastic channeling and then covered with self leveller , so then the grooved boards wit the single pipes are the gypsum based will the anhyfix stick to the parts that are covered with self level or does anhyfix have a problem contacting with cement based leveller , as it seems a bit strange having 2 materials to cover
hi
anyone give me some info on the dural decoupler or tile master matting , question re dural i know the tile masters anhydrite adhesive does have to be used below on the calcium sulphate and then can a flexible cement based adhesive be used on top of the matting or will it leach through and cause a reaction ?
TM Anhyfix to fix either the dural CI++ matting or TM Anti Fracture Mat (if not used the TM Anti Fracture mat, you'll find it perfoms exactly the same as the Bal mat.) I would use/advise TM Setaflex ontop of mat.
Ok, received this from Dural Uk
"The CI++ matting would work with the Gypsum adhesive, as all you are trying to achieve with our matting is to embed the fibres of the fleece layer into the adhesive.
The critical part is achieving the bond of the adhesive to the subfloor."
Reply to decoupler matting in the Australia Tiling Forum area at TilersForums.com
hats67 - Yesterday at 11:48 PM Add bookmark #1 Hello guys. I came upon and registered with...
Hello guys. I came upon and registered with this forum while doing some research on decoupling...
5K
Hi folks, We're having our downstairs tiles installed soon, about 82m2 of 1.2x1.2m square...
decoupler matting
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
