Guest viewing is limited
Discuss dewalt SDS leaking oil in the Australia Tiling Forum area at TilersForums.com.
I have an sds by dewalt that has grafted and never missed a beat for me. I use it for mixing up batches, drilling holes, tile removal and floor breaking, where it can cope. I heard Bosch took over dewalt and their tools haven't been up to the old standard however I don't know if this is just people chatting poo.
After 7 years and the previous owners bashing it has started to secrete some oil from the side...
So tonight I went and picked up the Makita on offer in screwfix just in case this one goes however I think I would rather clean it up and fix what Im guessing is a gasket then sell it on and use the Makita as it is a 3kg one and Im assuming will cope better.
Does anyone knowif my guess is right and if at all it can be repaired in a DIY fashion.
cheers peoples
SDS breaker or drill?. If its a breaker (im sure you know) then there is usually a accessible compartment that you have to put grease in quite frequently. If you use the breaker for too long a period the grease gets hot and melts leading to what looks like oil coming out. If its a drill then as far as I know there are no grease points accessible. Hope it helps.
Reply to dewalt SDS leaking oil in the Australia Tiling Forum area at TilersForums.com
Hi, We had a partial wet room installed in our first floor bathroom over 3 years ago by a...
8K
Gemma
Hi, I would like to get some opinions on using marble stone on walls. I was going to go with...
5K
Hi, Had a bit of nightmare at work. I poured some floor level onto a step which was to be tiled...
5K
swanman
Hi all, Well the D24000 saga continues. Have been having real issues with setting up the...
2 3
11K
Im involved with a large renovation project at the moment and due to other jobs on the go and...
South Woodford
Business Name
Complete Tiling Solutions
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
