Ditra Matting Adhesive
Sorry dave didn't see this till now but yes they do work although if you can pick up a reasonable priced SPF that works as well. (Someone told me that in the beginning with Ditra Schluter reccommended Blue Star I think to fix it). They still to this day insist you don't need to use modified adhesive once its fixed down because the membrane will take care of the movement.
Kev
Morning kev...
That quote is from schluter.com...for some reason schluter.com say un-modified adhesive is fine to tile with porcelain etc to Ditra....I wasn't happy with this because we have different scenarios to tile to than the USA does....
So i contacted schluter.Uk and got a reply from steve dennis one of there senior managers....and we can use any modified adhesive if tiling with porcelain etc.....here is his reply....( i did post this a while back but i will again for newer members)....
Dear David
Thank you for your recent enquiry regarding the use of Schlüter®-DITRA and it’s compatibility with cementitious adhesives.
Whilst the Installation Guide found on our American sister companies web site is generally generic, it must be observed that it is written for the North American market, therefore it quotes ASTM standards, which do vary greatly from the ones we use in Europe. In North America they use different parameters to classify adhesives, based on formulation and polymer types, also they need to take account of the various environmental conditions (temperature and humidity), throughout the continent. We recommend that all information for the UK is obtained via our own web site www.schluter.co.uk .
In Europe we use BS EN 12004 for adhesive classification, which we use ourselves in the UK. Cement based adhesives suitable for Schlüter®-DITRA are normally classified C1 or C2 adhesives based on the tile being used.
The use of BAL products with Porcelbond has been used with Schlüter®-DITRA for many years, which are generally classified as CT2 adhesives, we will generally advise that when using a highly vitrified tile a Single Part Flexible type of adhesive is used with Schlüter®-DITRA, depending on application.
If in doubt our Technical Department is only a phone call way.
Yours sincerely
Steve Dennis
Senior Business Development Manager
:thumbsup:
Dave,
Actually they quoted this info when I did the Schluter 1 Day course at Schluter UK. The biggest bone of contention at the time seemed to be could you go straight onto floorboards with Ditra without plying first. I rang Schluter Germany explained and they said yes as long as the boards were fixed properly and were rigid so in other words this meant fixed to BS and screwed at at least 300mm centres. Schluter UK however said in a later communication it should be plyed first. I have laid quite a lot of tiles straight onto boards and never had any comeback. I used the cheapest contact adhesive I could find out of my local Selco to fix the Ditra and always used SPF to fix. This does not mean I won't get any comeback because I only used Ditra for the first time in Dec 05 but time will tell eh!
Kev
It wasn't the sticking down of the Ditra that concerned me kev..it was just tiling onto it with porcelain/vitrified tiles and using normal setting adhesive and not poly-modified to get a good bond......but at least steve dennis sorted it out and clarified the situation......:thumbsup:
I know one tiler of 30 years and he uses ditra on all his floor board jobs
As long as the floor is solid then yes no probs..great product....and durabase as well will do the same job.....contact wetdecs for a free sample and compare the two....you will be impressed....:yes:
I intend to try durabase on the next job family or personal job. I saw it at the KBB and was well impressed and the fact that it was a lot cheaper than Ditra was a big factor:thumbsup:
Kev
Just bumping this thread. If it's not a current topic then don't worry about it for now. Other threads like this can be found in the main tiling forum. If you do want to reply to it, please do. Your information may add value to somebody reading the forum in the future.
Mike Strutter,
Dan,
Mike Strutter,
Dan,
