Discuss Do i need insulation boards in the UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,083
1,323
Staffordshire, UK
The extra cost of insulation will always be clawed back through running costs, over time.
Though that aside, the performance of the UFH will be drastically increased if you use insulation. The warm up and cool down times are both improved meaning with a digitial thermostatic controller the heating will only ever be on when it needs to be.
Ajax123
1,213
Lincolnshire
Minimum BS for sand cement floating on insulation is 65mm.
If you don't use insulation the electric heating mat will have to work very hard as you will end up trying to heat the screed as well. That will significantly impact response times, costs and life span of the heating system. It will also act as an uncoupling membrane for the tile face so the defficient depth of screed won't cause a long term issue.
Reply to Do i need insulation boards in the UK Tiling Forum area at TilersForums.com
    • Friendly
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
