Discuss Dot & Dab travertine? in the British & UK Tiling Forum area at TilersForums.com.
Alberta Stone
Plaster board is not a good choice for any wet area period.
Gypsum is food for mold.
So if you want to create a toxic mold culture in the client's bathroom then go ahead and use that gypsum garbage.
Always, always, always use cement backer board in wet areas.
Even better in our age of advanced materials use Magnesium Oxide (MgO) board.
Lots of places you can find it now.
Use a waterproofing system as well in all wet areas.
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
Don't mind me while I bump some old but popular threads to see if the topic is still active in some way. Wondering if either the original idea or original issue still exists. I've done this with quite a few threads, so don't be offended if this is just jargon these days and not applicable. But I thought there might be a small chance a small percentage of the small number of threads might just be slightly applicable and the thread could get a new lease of life.
Reply to this if you've read a bit and have something to say. :)
There IS going to be a bigger chance when i do this, that the thread is dead. So don't worry if that's the case, just don't reply to it, and we'll all move on and let the thread drop out of view again.
Reply to Dot & Dab travertine? in the British & UK Tiling Forum area at TilersForums.com
Hi all what adhesive would you recommend for dot and dabbing foam cored backer board onto...
    • Friendly
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Help please from any tilers. The plumbers made a mistake and had to rerun pipes after...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
