Drilling sets.
Drifterjoe
Hi Guys,
Advice on drill sets please. I have a set of porsadrill bits and a couple are soon going to need replacing.
I wanted to buy the box set of about 12 pieces that porcadrill make, but doesn't look like theit website works and can't find them anywhere. Have they stopped trading??
ATS and mexco look good???
Is a set of carbide holesaws a waste of time for porcelain?
If you had about £100 to spend what would you get??
All ats stuff has been good to me, the ones that go in angle grinders are highly rated, although I've not used them
Anyone got any reviews of the electro plated bits from ATS? Similar performance and life to porcadrill?
The brazed ones look best but are they worth the extra money?
I use Mexco ones from my local retailer and I find them very good . I'm drilling 45 mm hole in 10mm porc in 15 to 20 seconds .
My brazed Sigma hole saws are pretty much as new, very little wear after 50+ holes in porcelain.
I tested a 50mm saw on very tough r9 12mm porcelain and had 70 holes with approx only a third of the diamonds worn away.
Cheap coated chinese ones I can make last 10+ holes with loads of water.
Heard good things about the ATS ones.
Can use with battery drill but need to be kept wet. Someone said to put a bit of sponge in the bit to help lubricate.
They are sooo cheap.
Bout 4 quid for a 35mm bit.
At that price, they can last 2 holes for all I care.
The bigger they are the longer then last, my 115mm has easy done 70-80 holes and is just starting to show signs of wear
Had to buy and use a 50mm electro plated Genesis bit to day, knowing it may only last 4 holes, it tore through porc on 15 seconds.
Been using a Tileasy 35mm dry bit, and have been really struggling.
I know they arent the best, but have limited (no choice) off the shelf availability at my local supplier.
Looking forward to checking out the ATS ones.
ATS hole saws are very good for the price.
Electroplated ones stick a piece of sponge in the core & keep them wet & they will last a while.
I tested the dry cores for Alan & they worked great.
12mm dry core done 32 holes in grade 5 porcs one straight after the other & my arm gave up before the core did.
I use a grinder go through back of the tile and tap through front with tapping hammer .perfect holes .no stupid costs or extra space taking tools in way .old methods work
365 Drills have ceased trading but the same drills will be available through Encore Diamond very soon. They are UK distributors for Accura Diamond Tools (Ireland) who have purchased the remainder stock & buy direct from the same manufacturer. Branding and packaging has had to change for patent reasons
It did cross our minds to pick up the remnants of 365 but we figured it would need a complete re brand. It just didn't seem worth the bother, plus we'd have all those retail credit accounts and the thought of that made me shudder.
Pretty sure I met you at a tile show in Excel a few years back.
Just got my AtS bits, used a bit of sponge in them, porcelain tiles werent the hardest, but both 25mm and 35mm went thru in uder 10 seconds. Third hole with 25mm bit took no longer than the first.
Used with battery drill.
Shame theres no more holes to drill in this bathroom.
Drilling sets.
Drifterjoe,
Fraser Tiling,
Drifterjoe,
Fraser Tiling,
