Concrete guy
We've introduced a new range of Vacuum Brazed Dry Diamond Holesaws with M14 fitment to attach directly to angle grinders. Very similar to the Rubi dry core range or the Marcrist PG750X-M14 range.
We don't see these as a replacement for electroplated holesaws, rather a product that runs along side and solves that problem when there is simply no option to drill wet. Or you may simply prefer to use these as opposed to the electroplated bits.
These are designed to fit directly onto the thread of a grinder/polisher and will operate at 10,000 rpm plus on any standard 115mm or 125mm grinder.
They will also work on variable speed grinders and Wet polishers.
Each bit is hollow even the 6mm size, so if you have a wet centre feed machine like a Flex polisher you can utilise the water flow. It's unlikely this will speed up the cutting or even create a cleaner hole, but it will extend the drill bit life maybe as much doubling useable lifespan.
50mm in length they will cut through pretty much anything including 30mm thick granite counter tops.
The range is currently limited to the 12 sizes shown below which represent our top 12 selling sizes in electroplated holesaws. We can make pretty any size though if there's an obvious yawing gap in there somewhere.
Any questions just ask.
