I'd be looking at more than £20 for a blade IMO
Actually these blades are what the marble/granite processing companies use, as i'm in Goa, India, my concern is vfm as well as quality, once i get the cutting machine, i think i will give this blade that's on offer before i import anything expensive. We are using a bosch 110mm blade for our hand held cutter which costs about a fiver here, which is an excellent blade and last well, this is the most expensive i have seen over here, it also works well dry on a grinder, no chipping!
I've had a rubi cpc in my wet cutter for 2 years, and it's cut loads and loads of metres, I keep a santone block in the tray and run the blade through it when it starts to tire, this exposes new diamonds underneth and gets rid of the rounded non cutting ones
2 years! that's excellent. we just run our blades through a soft brick(Sun dried) which does the trick.
I bought a Faithfull sintered blade for my little Vitrex Pro cutter, and it's done loads of porcelain/ceramic/stone cuts, I put it on in October of last year, and it doesn't look as if I've used it!!
Great stuff, these are 20squids aren't they?
My blade costs in excess of £80, I have bought 4 in 7 years for my sigma 10m, They are
Italian made and are the dogs dooglies.
That's almost 2 years usage per blade 7 pounds per month of usage, not bad, what blade is it and what kind of tiles do you cut?
We do alot of granite/marble and sandstone work, which comes in slabs between 4-7 ft in length and 3.5ft wide and 18mm thick, so you can imagine processing these to a usable size takes a lot of effort and many meters of cutting, all done on site.
