Discuss External steps in the British & UK Tiling Forum area at TilersForums.com.
obobsmith
Hi, guys i've got some external steps to do, never done steps of anykind their concrete and pretty level and I was just after a bit of advice wether I should tile the risers first or the treads ( I thought the treads then riser is just like bottom cut on wall and would shed water better and make joint look nicer), thoughts much appreciated.
DS Tiling
Brian, We all have our different ways. I start at the bottom and work up. That way i can ensure the overlap of the tread over the riser is exact and then i place the next riser on top of the tread with expansion gap. The main thing which i hope we all agree on is that the tread should ovelap the riser and that as lucius said the riser goes on top of the tread with a spacers gap.
albertjames
thats a great way of tiling steps
kneeling on the step you have just layed
who ever showed you that way of tiling steps is nearly as daft as you
Reply to External steps in the British & UK Tiling Forum area at TilersForums.com
External steps
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
