TT Tiling
sad to see that ,im laying on them floors every week ,with no probs ,dry them out till they are bone dry ,good sealer ,happy days
I had bother with primer on top of Gyvlon a few weeks back,
That primer looks like a neat coat & has just came away like a skin.
Should only be 1 coat of primer at 3:1.
As you say John, it will be an easy rip out.
Don't know but is it possible to be too dry?? This might absorb all the fluid, thus leaving a skin?That was my thought Stef, don't have a pic of what was left on the floor but I suspect very little of the primer as it's still stuck to the adhesive. As you say the first coat would have probably been sufficient and was a little confused when the screeding contractor had told the builder to put a 2nd coat of neat primer over the top. This would have formed a skin and therefore the probable cause of failure.
John I used AnhyFix & should have done a test area without primer.
It states a 3:1 coat though.
The tapers had been in taping the ceilings & had dropped (as they do) a fair amount of fast set onto the floor & I was struggling to knock it off with a scraper.
I think we are going to see a lot of failures coming up with Calcium screeds.
Didnt you sand the floor 1st ?
Just add to this one John, it'll keep all the info in the same place for future reference.
Did it straightaway Bri, can you merge the 2?
http://www.tilersforums.com/tiling-forum/71268-another-floor-failure.html
