Flexible Adhesive
Terry the tiler
Good evening chaps, I have a quick question regarding adhesive.
So I went to price a job the other day for another customers father, it's a riverside property built on piling all timber frame and unfortunately has a floating floor. Now I told the guy I wasn't happy to tile it explained all the risks but he's adamant he wants it tiling (or his wife does) so I agreed to do it but take no responsibility for any movement and cracking.
To be fair the floor is more solid than you would expect and I have got him to fix hardie backer staggard on top to give more strength and less flex.
It's an area of around 25m and the tiles are 600X600 gloss porcelain.
Now that you know the details I suppose the question I'm asking is what adhesive would you guys suggest I use, I would usually use a Weber or bal rapid spf but I suppose I'm looking for something with a bit more flex.
I plan to also lay a bal or ditra DE-coupling matt down first as well.
Any help would be appreciated, and please don't judge me for tiling a floating floor but this is risk free for me as once I leave it's his responsibility.
Grout ideas would be handy too. I usually go for mapei or bal microflex
Have a look at Tilemaster Ultimate. Single part S2 - you could tile a diving board with it 🙂
Some fitters don't like it because it's a little bit like chewing gum.. but the pro's outway the con's.
The fact you have agreed to do the job knowing it may fail, means you will be held responsible if it ever went legal . No matter what has been said or signed between you and the client.
Anyway ditch the ditra and use bal fast flex with bal grout and gt1 admix.
How much is the Bal s2 per bag? Very pricey i'd imagine. Everyone does a single part s2 now so i'd shop around. As @Andy Allen says, use an admix with your grout for increased flexibility
Su
Anyway ditch the ditra and use bal fast flex with bal grout and gt1 admix.[/QUOTE
I'm defo going to get him to sign it off in writing. I'm pretty sure I will be covered then.
That's the whole point of getting it in writing so that I'm protected if he decides to be a chancer.
Eh?..... that is so not true.
Actually, it is. If a tiler still continues with a blatant disregard for the customers property or safety, a bit of paper with a signature doesn't not mean the customer is in full knowledge of what they are signing or what the consequences may be. The tiler is the expert and if he carries on knowing that what he is doing has a high possibility of failure, he better duck because a book is hurtling in the direction of his head.
Regardless of what bits of paper are floating about with whoevers signature is on it, it can still constitute Wilful Negligence or Wilful Misconduct.
Why is it not true Tom....
Because each case is taken on merit. The deciding factors will include all evidence of why it has failed. If the client insists that the procedure shall begin, even though the contractor has vetoed that compliance, then that will be taken into consideration by the judge's decision. Nothing is ever black and white.
Flexible Adhesive
Terry the tiler,
Fraser Tiling,
Terry the tiler,
Fraser Tiling,
