FYI , here's a tip in case it helps someone.
We've modified the "dot/tile" method for SLC over concrete slabs. We set pieces of small mosaic tile (1" X 1") in small blobs of Laticrete rapid setting epoxy, and level the upper surface of the mosaic with a laser. The epoxy sets up within minutes, and we can prime and prep the area as normal for SLC.
Then, when pouring the SLC, gauge your placement of the liquid so it just barely comes above the surface of the mosaic dot. If you do it correctly, the surface tension of the SLC will "bulge" around the mosaic dot and won't flow over the tile. Then, with your SLC rake, you can swoosh the liquid in that area a bit and the surface tension of the SLC will break and it will flow just barely across the tile.
We'll do 25-30 bag pours with just 3 of us, and as we say it's all "asses and elbows" while you're mixing and pouring and raking. There's no time at that point to worry about getting the levels right.
If someone hasn't already tried this method, I hope it helps on your next job.
