Discuss Floor Tile Lippage problem? in the UK Tiling Forum area at TilersForums.com.
After lots of similar frustration I've come to the conclusion that there is only a very small amount you can do with adhesive to correct poor floors.
If you want a flat tiled surface, you've got to start with a flat substrate.
Large format brick bond is always going to present problems unless your floor is mirror flat (or you dot n dab:joker
I HATE brick bond:furious3:
Press the tile into place...butt up to the next one you dont want it to lipp against....and run your hand across them to see if they are flush....if not take appropriate evasive action....Gaz
Reply to Floor Tile Lippage problem? in the UK Tiling Forum area at TilersForums.com
