borehamv
I intend tiling our bathroom floor. This is T&G boards with currently a 6mm ply covering for the existing floor covering. What thickness ply do I need to lay to get the right results.
Discuss floor tiles in the Best Floor Tiles area at TilersForums.com.
Thanks for that. Watch this space, there Will be more questions!!i would say at least a 9mm coard mate of exterior grade, put the rough side face up and then lay using a flexi addy and grout
depends on floor spring it could even be a 15mm board
andy
Thanks for that. Much appreciated.6mm is certainley too thin, minimum recommended would be 12mm to 15mm for most general uses unless this causes a height problem. If the floorboards are in good nick and securely fixed then you could tile directly on to them after cleaning, priming and using a product like Topps Tiles' Fastflex system. Not cheap but a very good product IMHO.
abskiing
Reply to floor tiles in the Best Floor Tiles area at TilersForums.com
