Hi everyone, I am a beginner starting another room at my home here in the US and want to do the French pattern again. Have unfilled unpolished chiseled stone and the tiles are 8x8, 8x16, 16x16 and 16x24. I understand the pattern but when you add the grout line to two 8's it ends up wider than the 16 it is going next to. What would a pro do? Should i cut off the chisels against the walls if there will be no trim?
I've seen it done two ways, one is what i call fudged, the other had the stone laid tight and grouted the chisels full. I like to see the chisels and want to clean the grout out of them.
