Getting wet from the wet cutter.
im using my angle grinder with a marcrist blade when ever possible these days instead of the wetcutter , ok you have to go outside but i usually set up the mixer in the cliients garage and do all the cutting and drilling there too, gives you more space to work inside...:thumbsup:
Ive just invested in a norton blade for the anglegrinder, not really a method i've used before but im going to give it a bash and try and minimise the use of the wet cutter and see how it goes.
Yea i've just got a Marcist for my angle grinder not used it yet...what do you cut onto (paving slab? use side of workbench?) do u cut the whole way through the tile?
to oli and freed !! the angle grinder is the tilers best friend , its the most versatile tool you will own ... practice on old tiles if necessary its not hard to use , its an essential piece of kit imo.... :thumbsup:
ok Andy but what do u cut down onto...i take it you cut through the tile so what do u put underneath?
you dont need to put anything underneath , if its a smaller tile you can balance it on your knee while cutting or if its a large tile sit it on a crate or workbench with the cutting line hanging over the edge, as i said before get some practice in with it , next time you are cutting porcelain tiles round a quadrant showerbase you will be screaming out my name in thanks !! :lol: :thumbsup:
sigma will cut it :thumbsup: with the grinder as andy p said practice and dont force the blade just guide it :8:
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
