Discuss green chipboard floor help in the British & UK Tiling Forum area at TilersForums.com.
andypar
Hi, i have a green chipboard 22mm floor that is on joist, that are screwed to concrete and are really solid, and am going to put down 40m2 of quartz tiles. The problem i have is i don't have room to overboard or if i did maximum would be 3mm, what is the best adhesive to use please. I have sanded a test area and moisture will penetrate this area a lot better than where i have not sanded.
Thanks, Andy
jwatson
if you tile straight onto them boards you will have problems! 3mm ply will be useless. a sheet of paper would be more use. the minimum over boarding you will be able to use will be 6mm tile backing boards and I am sure a de-coupling membrane would also be a very useful addition to your fixing method. BAL, mappei and weber are all good adhesives each have there own names for the adhesive you require for these tiles.
your end result will only be as good as your prep work, cut corners at your peril.
Reply to green chipboard floor help in the British & UK Tiling Forum area at TilersForums.com
Hi all, I'm an enthusiastic DIY'er (first time poster) who has been slowly chipping away at an...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi guys. Im a carpenter who has tiled a fair few floors over the years as i fit a lot of...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 2 1.2%
    Votes: 5 3.0%
