Discuss Grout Advice Required in the British & UK Tiling Forum area at TilersForums.com.
K
kinhell
The timber you can see around the sides is the flooring. There was 3 x2 timber there but rotten through.
Just to understand what you are saying, should I fill in the gap up level with the top of the tray and put lengths of aqua panel on top sloping gently inwards towards the centre of the tray? If so what would be the best thing to fill the gap with, mortar like the right side with a waterproofing agent?
DHTiling
I would remove the bottom row of tiles all the way around then build up the sides with aqua panel and flexi adhesive..then tank the aqua panel and the bottom bit of the walls...once dry then when you re-tile..let the tiles over shoot onto the tray a bit and seal the front lip with Silicon....the tanking and overshooting the tiles should stop any further probs.....nothings 100% but its worth a go....
Use cement based addy all the way and then no water will affect it...
But it is all in the prep work if you want to stop this happening again...
Reply to Grout Advice Required in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
