Grout Cleaners
how about sillicone cleaners the times ive had to remove dirty sillicone not because it let water through just looked awful
I use Aqua mix Heavy duty Tile & grout cleaner...i have tried lithofin, Hg etc..but find HDTG works very well. :thumbsup:
The biggest problem with cleaning grout is the dirt and grime soaks into it over the years, so you have to let the cleaners do it's work..give it plenty of dwell time, up to 30 mins in some cases, and sometimes it needs two applications to clean the grout. Be patient!!
Hi Rob.
If your wanting to remove mold and general crud and muck from white tiles in showers[You would be suprised with the state of some folks showers - some are really smart / posh]. The product that leaves shower grout really clean and kills all the mold - removes the red and black etc but will not remove other stains and general dirt is
Dettol Mold and Mildew Remover - formally know as Dettox. This stuff is a powerful biocide - spay on an leave to act - 1 hr to 24 hrs (repeat if necessary) and rinse. Cleans the shower valves, Silicon joints and glass seals etc - This product is not in your usual armoury of tilers and bath / wet room installers. I use it when asked. It stinks mine you - open the windows wear latex gloves and if spaying in tight space googles. Do spray on your best work clothes or customers towels as strips the colour out.
Tesco / Asda etc
There are three I reccommend.
Aqua Mix Shower Tile Cleaner
A Powerful Multipurpose cleaner that removes Soap Scum, Hard Water Deposits and Mildew Stains. Renews Grout Joints comes in a 710ml Trigger Spray Bottle and costs £4.29.
Aqua Mix Grout Deep Cleen
As above but for heavily soiled & Neglected grout combats dirt, grease & food stains. comes in 710ml Trigger spray and costs £6.99
Heavy Duty Tile & Grout Cleaner is a concentrated high alkaline cleaner & Degreaser. Effectively removes, Grease, soap scum, body oils,mildew stains and Algae from areas that have been neglected or subject to very heavy use. It will also strip synthetic waxes and flor finishes. comes in 946ml and costs £5.99
All available from Tradetiler.com Home a sponsor of this forum.
tel
Hi Rob.
Tesco / Asda etc
Really ????
if you are going to resort to useing household products then theres not many better than bicarbonate of soda!!!
Sir Ramic and Aston
I know it sounds far fetched, and yes its a 'household product' but it really works on moldy showers - try it and if your not 100%, send me the receipt and I'll send you the cash !
I should be on commission - I really only wanted to pass on this tip to help
I use it to clean my flask, it nearly makes me baulk when I see all the stuff it brings off. I was drinking my coffee outta that!:yikes:
