grumpygrouter
This is one of those funny situations in my opinion. A waterproof coating is there to stop water penetrating to a substrate that will be damaged by water i.e. plasterboard, plywood or mdf for instance. If the substrate will not be affected by contact with water and as a consequence the tiles stay put what is the actual pount of tanking. OK seal the joints but why seal the rest? If a potential leak through the tiles is so serious that it will start to "flood" through the substrate the volume of water would probably stay in the tanked area anyway overflow and run out of the door.....maybe?Hello,
I'm in the same position. I have just boarded out a shower area with backer board and was intending to apply a BAL WP1 kit. Why doesn't it need tanking?
Whilst the board is not affected by moisture I didn't think that it provided a waterproof barrier.
Mark
Just a thought, what do others think?
