Discuss Hardiebacker suction control? in the DIY Tiling Forum area at TilersForums.com.
V
Valleyboy
Hi
I'm a DIYer, done a few tiling jobs and don't think I'm all that bad at it. Just started refurbing my bathroom and have used Hardiebacker.
Generally no issues but being a DIYer I'm a bit slow. I've bought a slow curing cement based adhesive for this reason, to ensure that I don't waste much because of a short pot life and also to ensure that I have plenty of time to adjust the tiles if they need to be moved around a bit.
I have bonded a Classi-seal upstand to the boards and have found that the Hardieboard sucks the moisture out of the adhesive at a rate of knots. How best to get around this problem? Is it ok to spray water onto the cement board before tiling? Or I have some SBR here, weak mixture of that as a primer to help slow the suction down?
Appreciate any comments. Thank you.
Reply to Hardiebacker suction control? in the DIY Tiling Forum area at TilersForums.com
    • Friendly
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
DIY Tiling Forum
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
