gm renovations
Hi Guys
Just been to look at a job for a plumber friend, i am new to tiling and wnat to make sure i have covererd all the points,
The job in question is a bathroom, all the tiles have been stripped off the wall and in some places the plaster has been removed and some of the bonding behind is showing.
the walls are mostly flat but a bit bumpy, the floor is plyed out...
Wall tiles are ceramic (200x250 7mm thick) Floor tile 150x305 13/14mm thick slate) they also want some mirrored tiles place above the toliet and sink, these tiles are ( 225x225)
Areas Walls 22sqm and floor 5sqm,
i will get rapidset flex for the floor and white star for the walls, i will also prime the wood with apd and seal the tiles before and after grouting,
Normal pattern in the walls and brick on floor,
I was thinking of using a 10mm trowl on walls to try and flatten them out and 10mm on floor,
Any advice , guidence would be great, like setting the mirrored tiles into the tiles,
Many thanks
Gaz
Many thanks
Gaz
