Discuss HELP ceramic wall tiling on ply HELP PVA??? in the British & UK Tiling Forum area at TilersForums.com.
clm
hi dave.hope you can clear something up for me.i always use a primer BUT the 1 iv been using last year or so is from discount tiles and fairly cheap.it has had a shiny cling filmy look to it and i thought it just that make but just reading another thread(which month has run out and cant reply)it states that it isnt a primer if got a rubbery film.can you please enlighten me as if it isnt a tilers primer,as what they state,i wont be using agen and my friend wont be happy.done hers a few mnths ago-tiles still up tho(hopefully forever)and they cost her a lot of money as its 30m2
DHTiling
Usually if the primer has dried with a rubbery finish then you have not mixed it to the correct ratio..usually 4:1..4 parts water to one part primer.....it should state on the bottle the mixing ratio for certain substrates.....basicly if it is an impregnating sealer and not one that coats the surface( like PVA) then it will be OK...but as i said it will probably just need more water.....you also might want to go onto the primers manufactures website and see if there is a pdf or summit with more info on it and more detail on its uses........
GazTech
pva breaks down with moisture / water. need we say anymore about it?
Spot on Joe, Bal do not recommend PVA at all, as soon as moisture hits it it becomes live or active again and gives no barrier at all....these are the primers to use and check the spec on which applications suits you.....Gaz
BAL Prime APD
A modified acrylic polymer dispersion for use as a primer for a variety of backgrounds/bases prior to fixing ceramic tiles, mosaics and natural stone and prior to the application of levelling compound and the BAL WP1 TANKING SYSTEM. BAL PRIME APD isolates products containing calcium sulphate such as gypsum plaster and anhydrite screeds from cement-based adhesives, thus minimising the risk of reaction between the two materials.
Also suitable for use on cement:sand rendering, blockwork, plasterboard, cement:sand screeds and timber. It also provides surface strength to friable surfaces and reduces the porosity of porous backgrounds/bases, thus preventing the formation of air bubbles and prolonging the flow time with levelling compounds and extending the open time of tile adhesives. The primer is blue in colour to help ensure that a complete and even coating is obtained.
Coverage: Undiluted 100 - 200ml/m2 / Diluted 1:1 50 - 100ml/m2 Temperature Resistance: 5°C to 38°C Drying Time: 15 -30 minutes Packaging: 2.5 litre plastic containers Shelf Life: 12 months, when stored in normal, dry conditions. Store between 4°C and 32°C. Protect from frost. Store away from direct sunlight.
The Bal 10 Year Guarantee
Click here to download Material Safety Data Sheet
Product Data Sheet
BAL Bond SBR
A waterbased polymer with a wide variety of uses in the construction industry, particularly as an admixture and bonding agent for cement and concrete applications. Once cured, the polymer is water and frost resistant. BAL BOND SBR can be used as a slurry coat when mixed with hydraulic cement or gypsum plaster, as a multi-purpose admixture for cement:sand mortars, concrete and gypsum plaster; as a brush applied primer, sealer or dustproofer.
Suitable for use on cement:sand screeds, toppings or renderings, plastering, waterproofing, bonding, concrete repair, priming and sealing.
Coverage: Primer (neat) 12m2/litre, Plaster 5m2/litre, Render 0.8m2/litre, Screed 0.25m2/litre,
Slurry Coat 3m2/litre Total Solids: 47% pH: 9.5 Specific Gravity: 1.01 @ 25°C Stabilasation: Non-ionic Packaging: 5 litres & 1 litre bottles Shelf Life: 12 months when stored in normal, dry conditions. Protect from frost. Colour: White Freeze-Thaw stability: Good
Product Data Sheet
baltas1
GazTech
BAL do not recommend PVA with their products.
The primer that is recommended for a 4:1 dilution (for certain applications) is the BAL Bond which is an SBR (styrene-butadiene).
For MG/WBP plywood, it is recommended to prime the edges and reverse side with undiluted BAL Bond. For further info refer : http://194.223.92.131/pdf/Technical%20Data%20Sheets/B%20&%20C%20Technical%20Data%20Sheets/Bal_Bond_SBR.pdf
baltas1
Welcome to the forums baltas1, thanks for your input, the SBR is indeed styrene-butadiene copolymer, and has many uses within construction not only as a primer, but also as admixture and bonding agent.
Bal APD on the other hand is a modified acrylic polymer dispersion type which isolates products containing calcium sulphate like gypsum plaster, and cement based adhesives from reacting with one another.....Gaz
Reply to HELP ceramic wall tiling on ply HELP PVA??? in the British & UK Tiling Forum area at TilersForums.com
Hi all I'm looking at some Victorian wall tiles for an outside front doorway similar to this...
Hi, I’d appreciate some help with lay out for four walls with following measurements. I want to...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
Hi am re tiling kitchen and want some ideas as to what’s best to repair the walls after Remiving...
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
